OffRoadWarehouse & Bushwacker Fender Flares 2014-2016 4Runner
Toyota Pocket Style Fender Flare - Set of 4 - OE Matte Black​
Fits: 2014-2016 ALL except the LIMITED trim Packages
Part: 30921-02​
Your Cost is $499.00 with free shipping to 48 states
REBATE: Get $50 Back on Bushwacker Fender Flares!
Description:
With their recessed stainless steel bolts and massive presence, Pocket Style® Fender Flares are a Bushwacker original and an off-road icon. They're custom-designed for your Toyota 4Runner to complement oversized tires and high-clearance lift kits. You can mount them right out of the box, with their tough, OEM-style matte black finish - they're UV protected so they won't chalk. Or, paint them to match or accent the body color, for a factory-custom look.
Pocket Style® Fender Flares are made in the USA from our thick, warp-resistant Dura-Flex® 2000 material, tailor-made for added durability and flexibility on the trail. Despite their hard-core bolt-on styling, Pocket Style® Fender Flares install easily with only minimal drilling required. When you need maximum tire coverage with minimum time and effort, it's in the pocket. Pocket Style® Fender Flares from Bushwacker.
Highlights:
  • Adds up to 1.50 in. of tire coverage from debris
  • Installs easily with minimal drilling required
  • OEM matte black finish is easy to paint
  • 100% UV protected Dura-Flex® 2000 - no chalking
  • Made in the USA with a Limited Lifetime Warranty
  • Front Pair Part # 30045-02
  • Rear Pair Part # 30046-02
  • Front Flare Tire Coverage: 1.50 in.
  • Rear Flare Tire Coverage: 1.50 in.
  • Front Flare Height: 5.50 in.
  • Rear Flare Height: 5.50 in.
  • Front Aftermarket Bumper Compatible: No
  • Rear Aftermarket Bumper Compatible: No
Bushwacker products are designed to be installed by everyday people, incorporating full color images and easy-to-follow steps in a simple Acrobat PDF file that makes the process a fun project!
Installation Difficulty:
Vehicle Cutting Required: No
Vehicle Drilling Required: Yes
Installation Instructions: CLICK ME to see instructions
The number 1 installation rating is our easiest rating, requiring simple tools, minimal time, and little to no experience with modifying your vehicle. If you can change your wiper blades, you can do this with no sweat. All number 1 install ratings require no drilling or cutting to your vehicle.
A number 2 installation rating can require typical garage tools and some experience, and sometimes require more time and drilling into existing plastic components such as a wheel well liner or moulding. If you're familiar with basic shop tools, a number 2 install rating should be no problem for you.
A 3 installation rating is not something to take lightly, although our color pictures and detailed guide will step you through the process in the best way possible. Typically you'll need sheet metal cutting tools and have the experience with them to make the process go smoothly. The hard work and time involved will be worth it, though, giving your rig a custom look that can't be beat!
PM, Call 800-341-7757 or [email protected]​
AndiGarage
