Hey Guys,
I have a
2015 Toyota 4 Runner TRD Pro
Currently has 65k Miles, never used in 4WD and did only some Towing, but nothing extreme.
In the future i plan to do some mild Overlanding, but nothing gnarly.
The Toyota Dealer said there is no need to change the Transmission Oil until 100k, because it is a Sealed Transmission, and to be specific it requires a certain procedure with Pre-Heating of the Oil before re-Filling to make sure the correct Volume if Fluid is in it.
But they were not as sure about the Differential and Transfer Case... They only knew for sure the Front/Rear Diff should be changed every 65k miles.
Does anybody know if there is anything special to do to change the Differentials Oil?
Should i also do the Transfer case or should i do it all at once at 100k when i do the Transmission?
Thanks for any input... I am new to the 4 Runner World and i never owned an Automatic Transmission Car before.
I have a
