Oil Coolers
Poorboy64
For those that have changed the o rings in the oil coolers,
I have read differences in doing this. Looks that the easiest way is to leave the coolant lines connected and just remove the big banjo bolt R&R the seals with the oil cooler hanging from the coolant lines, Do not drain any coolant or oil, may loose a little oil when removed,
Does this seem about right?
Thanks,
https://youtu.be/G6OlHfOyFNU
A video I made when I changed mine. You'll loose quite a bit and I doubt you'll be able to get the orings off without pulling the cooler. It was baked on and had to be cut out once I got the cooler off.
Just drain it and don't worry about it.
DJNutshell
