Oil Pressure!!!
4x4runner91
Just want to see what avg. operating oil pressure is for the 3.0 V6...(while running under load and while idling at a stop)?
[L || | | | | H ]
Red is my idling oil pressure and green is my driving oil pressure
I've noticed after a oil changed i get higher oil pressure readings. also the 3vz is notorious for false readings from the OPSU so if you're really concerned you can change that out, its located right by the oil filter
anyone use Lucas in their oil? I've used it on several other vehicles with no problem...should it be ok in the 3vz? Is there something similar to add?
