Overhead console installation
gza526
Member
My runner was missing the sunroof switch form the overhead console. I just received an overhead console with home link. I was able to plug in the cable that powered the lights, but I cannot figure out how to plug in the sunroof switch. Does anyone know how to install this or have pics or a diagram of how to install the console? Thanks in advance.
Of course I have a sunroof. Why would I be trying to install a console with sunroof switch, if I didn't?
Do you have an OEM or an aftermarket sunroof? If it's aftermarket that might be the issue and explain why you didn't have an OEM switch to begin with.
The first 2 pics are of the console that came with the car. The next 2 pics are of the console that I bought as a replacement. As you can see the switch in the original console is missing and is just a hole. The last pic shows the wires that were above the console. I cannot figure out where to plug the red wire into. Also, I am pretty sure it is an OEM sunroof. Is there a way to tell the difference between an OEM one and an aftermarket one?
Do you have a remote starter or aftermarket alarm? That ribbon cable looks like an antenna or multifunction antenna/programming device cable for a DEI or similar system.
I do not have a remote starter or aftermarket alarm. For an OEM sunroof console, is it just one wire that needs to be plugged in?
