Overland Warehouse Compressors
As most folks know airing down makes a huge difference offroad, but it also requires you to be able to air up again. Don't get stuck having to depend on other or with an underpowered unit that takes forever to air up. These air compressors from OW deliver the same or better performance of much more expensive units out there.
First the compact dual cylinder model, great for most folks with up to 33" tires
Basic Air Compressor Kit
The dual cylinder design not only provides superior performance (25% faster than leading compact compressor) it also runs cooler for longevity, as well as being quieter and smoother in operation. The air pressure gauge is located close to the tire valve to provide accurate readings while filling the tires, this saves time and guess work. The air hose connection is mounted away from the compressor assembly to avoid hot surprises when disconnecting the air hose after filling the tires. Additionally it includes a nice full grip handle.
It fills a 31" tire from 16 PSI to 32 PSI in under 2 minutes, substantially outperforming the current leading compact compressor.
Features:
* Dual cylinder design
* Power requirement 12V / 30A
* 150 PSI maximum pressure rating
* 3 CFM flow rating
* 8 ft Electrical cord with battery clamps
* 24 ft Air hose with air pressure gauge
* Carry bag
And then the heavy duty unit for folks wanting to air up faster or larger volume tires (please note this unit its much larger than the picture suggests)
Heavy Duty Air Compressor Kit
The large heavy duty compressor is rated at almost double the flow rate of the compact basic air compressor. This unit airs up a 315/75/16 (35") tire from 15 PSI to 35 PSI in less than 2 1/2 minutes, making it ideal for wheelers with larger tires. It is a beefy unit measuring 12"L x 9"H x 6"D and weighing in at over 16lbs.
The air pressure gauge is located close to the tire valve to provide accurate readings while filling the tires, this saves time and guess work. Thermal protection circuitry protects the compressor from overheating. Additionally it includes a nice full grip handle.
Features:
* Power requirement 12V / 45A
* 5.7 CFM flow rating
* 7 ft Electrical cord with battery clamps
* 26 ft Air hose with air pressure gauge
* Auto reset thermal protection
* Carry bag
youngrk
