P0420 Error
808Sport
My 2005 4Runner Sport V6*is throwing an error and I downloaded the freezeframe data. Could you please help me determine if it is the catalytic converter or the oxygen sensor?
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 47.843 %
Engine Coolant Temperature = 190.4 °F
Fuel Trim Bank 1 Short Term = -3.906 %
Fuel Trim Bank 1 Long Term = 2.344 %
Fuel Trim Bank 2 Short Term = -6.25 %
Fuel Trim Bank 2 Long Term = 5.469 %
Engine RPM = 1,824 rpm
Speed (OBD) = 59.03 mph
Timing Advance = 20.5 °
Intake Air Temperature = 77 °F
Mass Air Flow Rate = 35.45 g/s
Throttle Position(Manifold) = 25.49 %
Run time since engine start = 441 s
O2 Sensor1 Equivalence Ratio = 1.058
O2 Sensor5 Equivalence Ratio = 1.021
Distance travelled since codes cleared = 23.612 miles
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,489.1 °F
Catalyst Temperature (Bank 2,Sensor 1) = 1,489.1 °F
Catalyst Temperature (Bank 1,Sensor 2) = 1,325.66 °F
Catalyst Temperature (Bank 2,Sensor 2) = 1,325.66 °F
Voltage (Control Module) = 13.593 V
Engine Load(Absolute) = 49.02 %
Commanded Equivalence Ratio(lambda) = 1.053
Relative Throttle Position = 6.667 %
Absolute Throttle Position B = 59.608 %
Accelerator PedalPosition D = 28.627 %
Accelerator PedalPosition E = 44.314 %
End of report.
Thanks in advance,
Scott
Sent from my SM-N950U using Tapatalk
