Parting out Several 3rd Gen 99-2001 (N East - NH)
How much for the transmission shifter assembly? I need a couple parts from it including the trans. shifter lever handle assembly, the transfer case shifter job, the transfer case shifter rubber boot, and the transfer case shifter black leather boot.
limited passenger rear bumper corner, bottom of rear fender flare with mud flap?? cost shipped to GA?
Do either of these trucks have ABS?
How much for the a rear axle shaft, bearing, drum brake assembly, and dust shield? Basically everything that comes out attached to the rear axle shaft.
Shipped to 75701
Russell
Shipped to 75701
Russell
Yes, they all have abs but I will have to check the conditions of the whole thing. Also, are you looking for both sides or just one side?
Fola
Do you have an e-locker wiring harness and switch?
I do have them but I have not gotten to the point where I am separating these wires. It's tedious. If you are willing to wait a bit, I am sure I will get to it. I am not quite sure how long "a bit" will be.
Fola
One side, either side. I believe ABS/non-ABS axles shafts are interchangeable but let me do some research to make sure. Give me a text or PM with a price + shipping quote when you get the chance.
Thanks. (903) 975-0638
If you plan on using the complete set as is, then the side matters. I will take a look and get back to you.
Fola
Wondering if you happened to have one of the retractable cargo covers (tan or black), and if that Pioneer double DIN head unit is for sale?
I do have the retractable cargo covers in tan. What year is your 4runner? I believe the brackets of the covers vary depending on year. Up to 2000 are same and 2001-2002 are the same.
The double DIN head is broken.
