Specs: 03 v8 limited lifted by 2.5 spacer, 1.5 body, 305/70/17 Toyo mt's.
Truck gets maintained well and wheeled pretty hard. So I'm not surprised it broke. I'm looking for a permanent solution.
I need to drive around in 2wd for about a week while my front diff bracket is getting copied into a beefier piece.
I tried taking it off after work and ran out of time. I pulled the rear flange bolts from the front drive line. Put the truck in drive and got nothing. Duh. Locked the center diff and still nothing. Did I not give it enough time to engage? Out of time I put it back together. What am I missing? DO I NEED TO PULL THE ABS FUSE so that the ecu isn't going crazy? If i do that will it stop me from being able to lock the center diff?
Why I am here with this truck: I broke my bracket the first time doing donuts in the snow center diff locked in 4hi. Wiped out the passenger axle and dented the oil pan. Drove it home slowly. I welded it and thought that it was fixed.
A month or so ago I was hopping in some wet snow. Not even pushing it and bam. It sheared the metal. I did NOT box the whole arm and could be why it broke again.
I need to pull the bracket again and send it off to a buddy. I was wondering if my rig will move with the front drive line out and center diff locked? I've searched for the last hour to find out and can't find any info. Also, will it damage engaging it?
Thanks for any input!
