Conspearasea
Mine is not nearly as bad, and has a ton of beach and salt water.
I run steel hull Commercial Vessels as a Sea Captain and spend my life fighting rust ( or at least making sure the deck hands are doing it right ). Ship owners don't like to see their $45 Million dollar vessels waste away, and we spend tons of time and money battling this problem every day.
I plan on getting out the angle grinder with wire wheel to lightly clean it. Next step is a "neutralizer" like "Ospho" which you can get at west marine, this is phosphoric acid that will neutralize light rusting.
There is a better product if you can get your hands on it called "EnRust" that becomes a true primer barrier after conversion for your top coat. Napasco I might be using this instead of Ospho.
For Really tough rust, Rust Bond is a two part converter and sealant that makes a rock hard film....I don't need this much protection at this time.
Another product easily available for small projects at Auto Stores is Naval Jelly.....diluted and gel formed phosphoric acid basically.
Final step for me will be Por 15 paint....I don't think Rustoleum will even come close to the longevity of that stuff, and I dont want to do this project twice. I plan on having this truck for many years to come, and this is worth the time to do right.
I might actually have to do a write up for this project when I do it, I've spent so much time on making this rig look the way I want....now it's time to take care of the part you rarely see.
