Prinsu roof rack install
climone
Hey guys,
I just got a Prinsu roof rack for my 2008 4runner. I am nervous about drilling into the roof. Does anyone know of a thorough install guide or video? cant seem to find one.
Thanks!
Yep, no drilling needed.
Instead of the spacers, I went a cheaper route that worked pretty well. Used some 3/4x3/4 aluminum bar stock and drilled the mounting holes through that.
https://www.amazon.com/Pieces-ALUMINUM-SQUARE-T6511-Stock/dp/B01F80WM02
For the front or rear (can't remember which) I had to also stack a 3/4x1/8 aluminum strip (from local big box store) to bring it up a little bit. The spacing is nice and tight without touching the roof, about 1/16-1/8 space between rack and roof.
Run a tap through the roof mounts to clear out any old loctite, I stripped one before I figured this out. Also be extra careful not to drop one of the nut inserts in the roof, if it falls in you have to pull the headliner to put in a new one.
mine sits level and used provided spacers
x2 Mine sits nice and level with no issues.
also big x2 on gratuitous silicone usage. I basically filled the spacers all the way up, then pushed the bolt through it and into the nutserts in the roof. This is an area where you can't use too much and it is truly cheap insurance against leaks and water damage to your head liner/etc.
Like others have said, its an easy bolt on. There is no drilling required. Everything included in the box was needed to install properly. The spacers included set everything up nice and level. I set mine up on the 4runner piece by piece, but you can also loosely bolt everything together and then lift it on the vehicle. Took me a couple hours to put it all together.
Only thing you'll need are some tools, silicone and some rags to clean up the roof when you take off the old rack.
You can check out my insta (@shadow4runner), i took a couple photos during the install. A lot of guys who answered here helped when i asked as well.
I know I know I'm anal. This was my front and rear gap with the 1" spacers provided. I went to 7/8" spacers in the front and 3/4" spacers in the rear with a smaller ID.
Agl11pt3Bdihg2-urguTsPo3Yeh9ndR20LiRmGGsyUhiIZZA_R_41rpO5XhxoWuhSgSaOeriIb5so4mtEGu6t6iJCzi0QzsJ8GGKCvqmHDGLAOFLGfyGORC8_2A9QlVXLvtLdYFY_J2YJ9u1ei8z9f4rw4rBjsXJR8G-MR5eJ4i7VPXPgGGAgQKrAC1AGVAOOXWMt5PGqhH9unBTQMnMCgx9YRFSGmu5InBKTroNGpUCt5lzN3SfLev1BdmmsQYDJuvCcfYzK7AGzRuSA6FKm7k_QvOfIOPaW6SYmgnE6y8wmNT9N_GQFCG0nJNANtMJkKY4GLcd2AIq4z4ueGtjtiVZvQ7rIfpSUI7eFgkcjWcFk-0VwHnrkSIutIstVLN13xV8LFX0dUM5pgXT0-ErFyPRIB_OnSBIo6ykPQ0D9_0HErZL6wYsxiQKeL3D8t60c3mZw_orVdP_eSzH72QbcxjEtMv2tVKxDbTey0H4CDTBueMMciZbqUCCp5mU_IpC-VHiaxqJnzTF4jYIXV9gYmajtGI7348jQYCVJg8LWA5YIKt2C01Bc4m0SSLOHJSUOfR6MVW94KYYQbpvHolIjN7lJkjTkOZyta0_JRYz7YAKlgcDJgW4406i9ZAP4pbVMnxxyAfblpJRUwsDmMKHJscQ_txOf9fAlZkt-2d6oiahEbJc4UPMPE619oAxsgXk_1lQfLXCso7zWP7E30mvkI_M=w658-h877-no
lrIHAaB8n_8vmcIT8ywlg4a75YjDc2VBzATduU52xxa0zFgiN-mNimJQHd1x5uvRHhczqecbJx8resoZPEngH1dU80P39V8G3Zrl_gDCEG477hajID1R1FCSGTlJ80YQx1CapT1axmybxen6MAiKeJT6siYS3fvUZdpwRrGMFfFv6b5q6DOX0upo02GxcW8cZHo2sb86IBgglk3EhNznPXOt2RYWSJ2tlfNFnQtDDbNZxjGt-dX4H9_X9Zfafh7pM0nXYC2ElHFux4fhxYDCDf7rIYQk8FVaz6IGi7zvlj4EeBgtqvdfmlOaNDPR4__0z06MJH_i6PCER8ESQPvu-USm3O2JjR3J4JQMhScpne19V67q7OAO_VnyqQ6bocnfFcFx7OP5PSVbwalXnAcu7wCHibFmEdANPH49kOUZA5cBKeoztSmc_evkomQB4Y8isT8jTT0pz4wCajqaNxdwJ9t0kA3ErMiFrGzGTK_S9KrqUiGyntCrQJJ-BguaXsrhHCekrj16HGhw4SQolcHhPswLt-G3GBkYdmemFUtl2FUF6Wn7pdjT_bgx5e1EYH3JYRNZRZE8IXT2uWewDqOxaDTFIv7XqlPL4HX3Z5G2JuVSF4cNhmAxdmaGHjNfjXxyGVsFg3Xr2jXRFeKKR-6Jtrn0HuKKE5c8y9EPBzWWMm-CTkzxTZ-Be_nyDVQdmwAxzrhqgHsLYkHclplWGGcP7i-9=w658-h877-no
here's the after pics and a blurry comparison of the spacers
2StLICPvAffEpYs2yFQ47aGdAMq1MhrLH6K4wqPNtVaCSEjssNXa6xyMF6f_bjJNKbbtbJ42ypXsqlc1_LWAdZ1zLBTbD5-MuO2yFOwsM5OpK-NthgOthiKCAnsjtHusYrnsO2nQxWj-7Ts8tZdOc5jXokM-Y1N97etXg-doskXsCsFcBBJhly0fKCVYLZDmYfkGdXxK0Cjuhi4HCtWkloK73eCb4p7VeSIj4XpqAAY2XhB6eCDTxkoYG60tuVV3iTvQfS5h7dVagVSmfHkG3QYpPTElTb7RwRcv-wgBr1q2hdcSxLxWx2h96Yud1IaoE1lyZ0GQFM_dtG_cC4KgH3rzBsfl4_QMvFX1I0xbN_GBaKuDZYBCCy3jrncuSRyrOK3nqtH53a3I11YXSE4fzYwNbwJwOJgUfAzCplJaMGYCmoFOHwuauoxpEnyiU0fLAc-OwUfvyHOke4CuPykWMxxNL2YR9YfgBUNN9v-jXAUi7xrPEQLyfxNO9u6QfMC_A8OB1YhxhNHADmPawE4MCiRJqxFFq9sE0vzP6D4sS8aTN00Vry9bZc_qORmIAh0ovpLNwGWvhtb3nmOeWP0W5TFOKcMTNUYd6hJK-xUwy1FDTGZ5lnukfbvPBCad8epKvvbow3qezmt2j-w3GhU7TRoDUlaIqOobAO8Pw60uBpVhZzllH1Gsp53VzNaegls3Lg04pQZdhEyP52p2OkjWKci1=w658-h877-no
suJb2CaM3MnuOWInM7Ngo3vJyzSHQczGcKTUPqiBJd3XVYB0WZVBi3yr-tmm7pDfVlMrHb2ek47VBUjbPQCCfnkTb9oatwpsYZ2i27_Ix3YbV8YHqNS3Gm0xRdtWSe-fDc96kRKh71uNsCE6jjOIth-re-jwYRVxRK1gmHFvk9se3lnykrk0oZEGsQ6J59tVQpnMjT32MkpJVX6svbWWJVumGCpVQdwqoRjVCHulGeBAoVISfWOzxGEF51D0rqLoLYjyHYisI_A9wFAxlM8C2uFbHuFiguGZzfWF4WTUdm5zD0Y0adoIRTIrwjNVoU_W8LAC7AXq0tD5cZE4EVG1cXgCasRhWj_P0AGhRNyekhAo7rA78LHuKOD9hm_4zfo4BH4cgsb23kQxAiZroqGTqaLB6O31i-UF7iEY-prXYx15WQX0OAZkZvsIMp5dqHSaT970AqQB4naYepN4M6OFeNvbgbNXANHdkZdvCgCqLVyVcoTn-aK7MDkfGoCoAaSfZTXaew3MBKhRAUgjQYaCpUwmaaRlPH_8f4oqQCiDdRxD6Llpf24pmgjOMaXFOAJ2P_2YGtkk5uhRtF8QploLCjJ1LmGlZQ9T87VxCRF5zzKFHfX9nxn2Uc00CZTNhRVlpFmP9rm4HYO1qaEdLOTHPglI6NuVBwKV7Z9TbVYp-GDwnO3vODVsGzBT8x5wy6MYHwLnjUOBjKdFhiVUkopY0PX_=w658-h877-no
y8u8kA9fyB_Tm1FbidjtZkClpER_MxA16IL5mWu0h9IbuLuKHUE37uO-5aljU5U2neHSvvMyivKjuGvTnqEP9aReS5_Dp28M4oLm4k-r7pTMdG1l9LwxBVleuOGBXvk2TAJ64IReiLxgSMM91blICvdblthRRz8yhWdyGGeJLuksCgNkZ_iDgHDcmy-C5eHFaeuAIxQdcsgQYBO43bE54Uf1xB--FofiI9tVR3CxusC3jtpZ1rMG4IAe3kqbHydzLOiAoFVsftDjLWfF-XMUujiW2egeJqWDpnUJoA_MIlNgjgQR5X6WvoUcbE_xyUMn8KoFqulorYstIfd8BiCLc0ZgAu1P_0LUXlJSxVgaX7sSdcHciN-fhEV0LpdP0RSQ2GXxGB29K5GH4w6a_g9Ll6DVy3m9cmDRjUJFnKbElRPsmnbupXQCTo3GQSrFtnDbbVbauwBTJp_7MHaz1cM7wht_ylKKW8lIoGsP3tM4kaqcGOcnzyqdDmBVpUMO2hnDYjZX8HLX9-us3D5JMxdJWBHfQ_tNpsgwRP8Byj06scFjSJPU5vSuCM14Q9eD40wBxyPPIwcpc6pUHc8rE9_BnM1k4VBmAdM-h5qVpKzLpbx3OxW52j2N2SsQMo10J-PPA3xyqxmE-9VowKmgIsfGCoc9G6WgdRGm-XnKIIBStobE8jSpQBl4AFVOGok1-ZixS3FRyQVZClekDAL_0BY0TipG=w1169-h877-no
you get these off amazon too? if so what will be the safe ID to go with ?
The old orders link takes me to a different part now that doesn't have the right ID. I used some that had 3/8" ID marked as 0.38" I suppose you could go slightly smaller ID even, and worst case have to drill them out a touch to fit the bolts.
Descriptions from the parts I bought back in 2017
"Round Spacer, Aluminum, Plain Finish, 3/8" Screw Size, 3/4" OD, 0.38" ID, 7/8" Length, Made in US (Pack of 5) "
"Round Spacer, Aluminum, Plain Finish, 3/8" Screw Size, 3/4" OD, 0.38" ID, 3/4" Length, Made in US (Pack of 5) "
