blizz86
So a few weeks ago i noticed a shuddering when braking under 5-8 mph on a downhill parking area, and then again at a nearly level surface when the engine was cold. I didn't really experience it much, but now its back. I have narrowed it down to basically only under COLD start engine temps (tranny didn't have time to warm up yet), with level to downhill grades.
I can think of only one instance when I have been the cause of any tranny damage. I was replacing the inner axle seal a while back, and i was being a huge idiot and put the truck in gear (without the drum on the hub) to see if any more gear oil would leak. The speed of the wheel wasn't too fast but i definitely know i damaged it a bit when i couldnt stop it any way other than forcing it back in park. (Looking back, i probably should have just turned the car off in gear and let it slow down on its own
I also drained/refilled the tranny fluid with Chevron ATF (meets our t4r requirements, and i didn't measure how much i drained. I basically filled to manual specs, and it wasn't at the proper level under warm conditions so i kept filling until it was. Now under cold temps, im well over warm temp ATF levels. Could this be the cause?
Could something like Dr Tranny Instant Shudder Fixx help?
Dr. Tranny Instant Shudder Fixx
or the LugeGard ATF protectant with LXE
LUBEGARD Automatic Transmission Fluid Protectant
