Pulling out shrubs
MSRP.
Is there a preferred direction to pull from for durability's sake?
Reverse gear vs 4-LO + rear diff?
It is my understanding that you should pull in forward rather than reverse, as the rear diff is stronger than the front. You will put more load on the front diff reversing than driving forward. Depending on how much pull you need, you may require to use low range for the additional torque. Do so, smoothly.*
Forwards! That way when it comes free and hurtles towards the truck at 100mph you stop it with the back window instead of your face.
This is another excellent reason to use the wheel technique described above. It's an old farmer's trick for pulling fence posts with tractors. With the wheel, the shrub lets go in a vertical vector.
Reverse pulling should be the last option if possible due to the size of the gear in the transmission. Now I've pulled with reverse in certain circumstances and always cringe at it. The tire pulling method or winch with snatch is always good :).
Sounds like a GREAT excuse to buy that winch :P
I would pull forward.
Also, if you have an old wheel or perhaps your spare tire, you can lay the strap over the tire and then tie it to what ever you are pulling out. This lifts and pulls at the same time. much better than pulling sideways.
a couple of examples:
https://www.youtube.com/watch?v=gq_Gb46eXr4
https://www.youtube.com/watch?v=eHC-AA1xj4w
Is there any damage that can occur to the tranny when you are pulling with the vehicle in park ? As opposed to pulling in neutral with the brakes on. I know on the grass it will just slide but on pavement where the tires can really get some traction.
You need weight, torque, and traction. The 4Runner lacks 2 of them out of the box.
Use low range and if your using a snatch cord you can use the rubber band effect to increase your pulling power. If you have a drop hitch flip it upside down and the shorter the chain or whatever the more it will pull down the read and aid in traction.
My 94 Cummins weighs 6300lbs. My brothers 2015 1 ton Cummins weighs 8000lbs. The 4Runner weighs 4,000lbs. Just to put stump and bush pulling into perspective.
Yes, of course. You can potentially break the parking pawl. If you are referring to the bronco in the video. I suspect he is tied off to that giant tree behind him, it is definitely not in park.
Let us know how this turns out for you.
Could get interesting, like we see WTB add for rear hatch with glass, JK.
Good Luck with the job.
Worked out just fine.
Used a spare wheel/tire to get some extra leverage, soaked the surrounding soil and mulch.
No window repairs needed (thankfully).
Pulling out tree stumps of any size you can forget about it unless you have a tank.
I pulled out some rather large shrub stumps about 2-3' in diameter with my ZJ. At first, it was a no go and I doubt my 4runner would have done any better. The trick was to dig around the base of the stump to expose the major roots. Then use a sawzall with a really long blade and cut through all of the big roots. Once I did this, it yanked them out just fine in 4lo.
We've even tried using a rather large John Deere tractor up at our hunting land to dig up/pull out tree stumps and it doesn't even budge them.
+1 and I've pulled out a fair few. Did this Oak tree not too long ago. 4lo + Diesel = Effortless!
https://www.youtube.com/watch?v=RXFZYaEhy7k
tuṣṭāva
