Purchase Advice 4th gen V8 SR5
Chupto
Hey guys-
Looking at buying this beast: 2003 Toyota 4Runner | KDK Auto Brokers Inc. | Brunswick, OH
Seems to run well and is clean, yet the mileage is worrisome. I think it will need at least a timing belt in the very near future. Other than that, I miss having a runner for the pup.
Troubling part is I heard bad things about the dealership and then they offered me a purchase of the "Preferred Warranties" aftermarket warranty for $1,500. That's a scam warranty, so I walked away and said I would call today.
Price is at for $6,900 out the door without the warranty. Any advice is appreciated.
Get it checked out by a mechanic you trust. See what he says.
You could stick that $1500 in an interest bearing account and hold it as your own "warranty" against any repairs down the road and probably be ok.
It's always a gamble on the higher mileage vehicles.
If you trust their mechanic, they may give you a discount on the timing belt job.
Not a bad price at all if it's clean and mechanically checks out. Timing belt would be a good idea. In your neck of the woods, corrosion may be an issue. However, that may be why it's priced as it is. Down here in the south I would expect the vehicle, if no rust issues, to be worth about $2k more.
Thank you
I'm going to try to negotiate and see what happens. I'll post again if I actually purchase. You guys rock!
Do the normal stuff, ie carfax it, take it to an independent mechanic and have a buyers inspection done, sleep on it for a night or two.
Don't ignore your gut feeling though. If it ain't right, walk away and keep searching. Took me a while, but am happy as I ended up with a great vehicle. I looked at dozens of 4Runners, and never liked the ones from the smaller auto brokers who buy all their cars via auctions. May work for some, but I wanted (and was rewarded with) a local one owner from a reputable dealership. Was not against buying private party, but the right one popped up and I sprung after searching hard for 6 months.
special attention to the 4wd on/off actuators
price and pictures sound and look good
one owner is also super good (especially if you can track them down for a few questions)
Ended up buying the T4R. Now I'm scheduling some basic maintenance. They're doing the timing belt and water pump for $300.
Do you think a transmission flush is in order?
That's quite a bargain.
Different people have different views on this. I had the transmission fluid replaced on my '03.
Congrats!
As far as the trans, I would do a drain and fill. A flush could be risky with that many miles. Also, since it's an '03 it is most likely not WS trans fluid and not horribly expensive.
Curious.... are they doing timing belt and pump (a 800.00 to 1200.00 job) or a drive belt (serpentine) and water pump (about a 300.00 job)?
Make sure it is clear...
Trans fluid should be Toyota type 4, (about 6 qts with filter and gasket) rear end is 75w90 synthetic (about 3 qts) and 2 more for the front. Don't forget new crush washers for the rear and front fill/drain plugs...
Thanks for all of your input guys!
Delz- They are doing a timing belt and water pump change for $300, I put that in the writing. I knew the vehicle had issues and pretty much just wanted it.
I took it to a reputable dealer yesterday, Summit Toyota in Akron, and Ian was my mechanic. He did a great job, and showed me the issues:
1) Tranny looked great - don't touch it or the fluid
2) Power Steering was brown/black sludge - flushed
3) humming noise was the right wheel bearing - I replaced it, watched how he did it, got pointers, and will change the left myself
Overall, the shop thought it was a great truck and said the previous owner took outstanding care of it.
I'm going to love this forum!
MaximussK
