Question about KDSS on an Trail Premium...
Matt2558
I am looking at purchasing a Trail Premium and it has the KDSS on it. My question is can you add a suspension lift to this truck and still utilize the KDSS or does adding the lift require removal of the KDSS? Just trying to find out for sure because that is a $1750 option that if I can't use it I definitely don't want to pay for it up front. Thanks!
You can lift it as normal with KDSS. And you will be fine. The only heads up is be sure that you or your installer follow the directions exactly on resetting the KDSS cylinder positions. It is not difficult. If the instructions are ignored or an alternate method is used you can cost yourself $1,000s.
Mike Sargent
