Quick Lift Question
RunningRick
So i got my toytec ultimate in the mail but i did not get instructions for the rear do i need a spring compressor to get the rear springs out and in.
no... you simply disco the shocks, and jack up one end of the axle and pop the coil out one side, and then move the jack to the other brake drum and jack it up til the axle drops enough to pull the coil out...
sometimes helps to remove the panhard but not always necessary
I put mine on jack stands and let the entire axle drop and did both sides at once, but if you don't have stands Duhockey's way is almost just as easy.
