Quick question on Lift
yeti_4runner08
I will be putting on some LC springs with new shocks for rear and new shocks and springs as well for the front. I currently am running daystar coil spring spacers. My question is can I still run the spacers with new springs to add more lift? Has anyone done that before or is it stupid? Thanks.
Like UnderFire said you can but don't go over 3" of lift in total on the front. It puts too much strain on the front end components. If you can get the 3" with just the front springs then that will be better than spacers.
What shocks and springs are you planning on using on the front?
I was going to order off of toytech and get a pair if oem springs and put then on whatever shock it matches with. Anybody have any ideas of what I should run? My tires are 295/75 and they are stuffed. I just want to be able to use my tires right and be able to flex and move unlike now. I am in the market for LC 8 wraps with bilstein 5150 shocks to run with those for the back. What would level front out best ?
If you order the Tundra Billies and either Tundra coils or Toytec coils, you can match the rear. The Tundra billies have 5 adjustable points, and with 8 wraps, if you set on the 2nd or third notch, you should be close to level.
Also with the front lift to relieve some strain put in front diff drop spacers. they come with toytec front lift kits. For the most travel up front go with the adjustable coils on toytecs page. The Boss or Icons would be best, if money is no option...
Exactly what I like to hear. Were the Tundra shocks used? any specific year for tundra coils and does it have to be front or rear? Would like more details on this I believe this is exactly what I want to do.
Look in the 3rd gen section sticky Master Directory, There is a whole thread on Lift information and FAQs. Everything about the Tundra coils and billies are in there.
DionicioLives
