The breather is simple to pull off and inspect. It sits right on top of the 3rd member closer to the driver side. Just spin it off with a wrench, blow through it and see if it lets air escape. But, there's a very good chance this isn't the reason for your continued axle seal failure problem. It's for the reasons I state below.
You learned the hard way that this repair is not as simple as just replacing the seal. Here's why:
Toyota redesigned the axle seal some time in the past. The new seal design has the lip of the seal sitting more inboard than the original. Without changing the retainer position on the axle, the lip of the seal will be barely riding on the polished shoulder of the retainer. With a little bearing play from worn out axle bearings, the lip of the seal will sometimes ride on the non-polished bevel and the seal will wear out prematurely and fail.
If you're tired of contaminating your brakes and replacing seals, you need to fully service your axles by either doing the press work yourself or farming it out to a local machine shop that knows what they are doing. What I mean by fully servicing is you need to replace your bearings and reposition the retainer so it meets up better with the seal lip.
If you have an ABS rearend, you can reuse the ABS gear and both retainers if you pull off the parts rather than cut them off. For the retainers, swap the positions. Put the one that was against the bearing in the position where it meets up with the seal. Then, put the one that was originally meeting up with the seal against the bearing. The reason for swapping the positions is because the seal lip wears a mark into the retainer. This area where the seal lip has been riding for thousands of miles has actually worn down the metal every so slightly. If the new seal actually rides in this same area, the seal won't be as tight compared to the seal lip riding on a non-worn retainer.
If you have an Non-ABS rearend, you only have one retainer against the bearing and you should replace it.
Also, when the seal fails and lets gear oil surround the bearing, the gear oil gets into the bearing casing and washes out the grease. The bearings are lubricated with grease and not gear oil. This compromises the bearing because it's not being lubricated properly.
[MENTION=102606]infamousRNR[/MENTION] and I have a couple videos you could follow as a tutorial if you want to do the whole job yourself. At the very least, by watching the videos you'll see for yourself why your seals keep on failing.
