rear bump stops
arehman11
At what point should you upgrade these? My rear is currently sitting 2" taller than factory. Would the Toytec 2" bump stops be appropriate or would I be better off with something like the wheelers super bumps?
You don't HAVE to touch them unless you need to modify bump stop height to control shock up-travel appropriately.
That being said, I did go with ICON hydraulic bump stops to control that last bit of travel. Do I NEED it? No. Do I like it? Yes :)
I don't bottom out often, but when I do, I prefer Dos Equis... I mean't super bumps.
I upgraded to the Wheelers super bumps front and rear. I can tell it's helped over the OEM stuff, but if you drive hard, and hit the bumps often it's worth spending more on hydraulic bump stops.
Jhunt
