Rear Control Arm Bushing Help
kpnavarro
I recently bought a set of suspension bushings from energy suspension because my rear control arms have a lot of play in them. I am havin trouble pressing them out. I could probably press out the middle rubber part but the metal outer part is rusted against the control arm. Any ideas how to get it out, i bent a ball joint press trying to get them out
I just cut them out. much easier in the long run, and you don't stress the part as much. Your going to love those bushings. You might consider a mixture of M1 syn marine grease with copper antiseize, I found this seemed to last longer then other stuff. Use it like your not paying for it.
regards
I was about to cut them out using a sawzall but i was just worried i was going to mess up the inside of eye on the control arm
rear control arm bushings
Just drill holes, or burn out the bonded rubber portion, then cut the shell with a hack saw. You could use the sawzall for a portion, but I would use a hand saw for the end part. I had to use a chisel on some shells, even after using the saw.
Best of luck, urethane bushings in these trucks are fantastic(no affiliation, just satisfied customer).
regards
I just finished puttin all of the bushings in, I ended up drilling all the rubber out and using a hacksaw to cut through the outer metal casing. It was pretty labor intensive but worth it
seltzernator
