Rear control arm links! Suggestions please.
Rjsimeon
Tried the search function and found nothing. Need suggestions on how to get my rear links to line up. Just threw some LC coils on and removed my links to fit the springs in.
If putting the driver side on first, put the bolt through on one end.
Using a floor jack, place it under the passenger side axle (opposite side you're working on). Slowly raise the passenger side axle up a few pumps at a time and check the alignment of the control arm bolt hole.
Once the bolt hole is close to being lined up, use a 3/8 drift punch or socket extension to line it up the rest of the way to get the control arm bolt through.
seltzernator
