Rear Diff Lock option?
I'm not sure if you have accounted for this, but you will need to replace the front differential to match the gear ratio of the regular (not e-locker) rear differential. You also can't install a regular differential in an elocker rear axle housing or vice versa. They are different bolt patterns for the differential to axle housing.
I didnt think about that. That being said the accident just happened a few days ago and i haven't had the chance to look at everything and there’s definitely a chance i have to replace the housing as well. Id have to take a good look at it but if i have to regear the front as well. I might as well regear to the gear ratio i would want right? I havent figured out if i want 4.56 or 4.88s yet but thats a different topic.
[MENTION=669565]D1n13L[/MENTION], A Yota OE locker can be installed in a nonlocker OE housing been done many times over last 20 yr. Lil cut here n there to housing relocate mounting studs not plug n play not rocket science either good writeups around the Web.
chasebradshaw
