Rear end harmonic noise
Mustangdave
I have a 2011 Limited with 112k miles. At around 50mph, I hear a harmonic noise coming from the rear end. Also, the 4LO, ABS, Brake, and Traction lights flash sometimes. I changed the rear diff fluid and greased the driveshafts in hopes that those had something to do with it. Could it be the rear bearing/hub? I've done a lot of research and can't find any write-ups on how to replace the rear bearing/hub if that's what the problem is. Thoughts???
delislerebecca
