Rear Main Seal
Exactly. You want a re-sealer. They recondition all engine seals by using a polymer that does zero damage to the motor. Do they work? Yep. How do I know? Cause I use them. A re-sealer will look very much like water when you pour it out of the bottle. A "stop leak" will be more like a thick syrup. Here's the backstory. Again. lol
I purchased my rig with 232,000 miles. I got a great deal and one reason was it had a very slight rear main leak. My plan was to fix that. I first talked to a mechanic friend and to my surprise he recommended Blue Devil Rear Main Sealer. After my own research I decided to give it a try. I put it in at my 235,000 mile oil change. It worked.
Then I changed my oil at 240,000 and did not put re-sealer back in. Then the leak came back. I did more research and came across another re-sealer. This one is the ATP AT-205. I put a bottle in at about 241,000 miles. It stopped the leak in a day.
Since then I've put 9000 miles on my rig and done two oil changes. I add half a bottle(4oz) of ATP at every oil change. There is not a single drop of oil coming off my rear main. It also stopped the slight seep coming off my oil cooler.
The moral here? Don't knock something unless you've tried it.
I have turned a lot of wrenches over the years. I was one of the skeptics about stop leak products. That was years ago before re-sealers entered the market. My mechanic buddy who told me to try this stuff has been turning a wrench everyday for 30 years. I trust him more then any random guy on the net saying something does or doesn't work.
I did a lot of research into how a re-sealer actually works and I am convinced that they do work for certain leaks and that they do not cause any harm to the internals of a motor. But then again, I'm just some random guy on the internet. lol
Nicely written. You may well have turned one of those skeptics into someone willing to give it a try.
Seal
Hi there...
4Runner - SR5
Need to replace engine rear main seal (engine oil leakage).
Because it is a quite a large and time consuming repair job, once I order / buy a seal ring, is there a possibility that inner mounting surface is scratched by old ring at the time of the previous exploatation? This would jeopardize the whole job i.e. repair? What are the experiences?
Greetings from Europe.
You can always vary the depth at which you seat the new seal. Plus I know sometimes (not sure about Toyota/OEM 5VZFE parts in particular) they will put the sealing lip in a slightly different spot on 'replacement' seals vs what was used on the original seal.
In general, I really wouldn't worry about it at all. Unless you're at 1,000,000 miles and you're replacing the seal for the 3rd time, the seal probably hasn't put very much wear onto the crank, not enough to cause a problem. The main thing to worry about is not scratching or damaging the crank while removing the old seal.
Hi there...
4Runner - SR5
we replaced the rear main seal as preventive maintenance when replacing the clutch in my '99 manual transmission 4runner. we did not observe any damage to the mating surface. the seal really shouldn't hurt the cylinder block. almost exclusively, if there's a leak, it's due to damage or wear to the seal. given the effort involved with this repair, make sure you buy a genuine toyota seal.
Thanks for comments.
Once, more than 15 yrs before, I run my 4Runner into terrible terrain (large rocks that "broke" the chassis diagonally). Very short after that I had to changed 2 reductor's seal rings. This may have been the belated reaction of that trip.
Thanks once more...
erinobr2000
