Rear suspensions
Qubit
OK don't get mad at me. I am a audio person aka a basshead. I have over 600 ponds just in battery I have helper bags but I am not happy with it what should I do. And the runner is a 97
are you currently running the factory set up just with air bags added?
look into replacing the springs with like a 2" lift to help lift up the rear, then when all that weight is added it should bring it back to normal height.
check out OME lift kits and springs. and or toyteclifts.com. call both companies up and tell them what your doing and they can help you out. toytec has great customer support.
With that much weight Im sure your sagging a bit. I would look into some 906 OME rear coils. These will raise you up 2" and will handle extra weight, but not made for that much. With new shocks and your helper air bags it should handle it way better. You may need to add a front spacer to match but maybe not with all that weight. Usually I dont recommend spacer but if this truck is for the road they work well. I would think about replacing old front LBJ's if they are original if you plan on changing any front suspension at all as they are prone to fail. Research around, here is a good place to start looking at some parts.
2.5" Lift Kit w/spacers & rear OME coils
Damn I got beat!!
