Redline shockproof gear oil?
KidVermicious
Red Line 58204 Heavy ShockProof Gear Oil - 1 Quart : Amazon.com : Automotive
Anybody running this stuff? Marlin says:
in high pressure use such as slow Rock Crawling, the special design of this oil reduces the thinning effect and metal-to-metal contact producing an effective rating of a 250-weight gear oil. Then, as RPMs increase, it provides three-times the viscosity in thin layers found in high speed applications providing less drag and a fluid friction comparable to a 90-weight oil.
Compared to typical gear oils, this Shockproof Gear Oil has 40% lower coefficient of friction yet has a 250% higher load-carrying capacity. This is great news for the slow moving and high pressure environments that Rock Crawlers are exposed to, and for anytime you really need to input a lot of throttle. In addition, Red Line has verified this oil to run 25- to 75-degrees F cooler in circle track, road racing, and off road racing.
That's incredible.
No, it's cool to know that it quieted down your Lockrite. My Spartan doesn't make much noise anyway, but quieter lockers has to be a good sign, right?
I'm using stock weight too. I know some people run thicker to quiet it down. Currently I have to listen for it in any turn except super tight ones. And only one "bang" like people say they hear on occasion.
Tyler, what weight are you running? The "light" or "heavy"? I am going to this after my Spartan breaks in a bit.
http://www.summitracing.com/parts/red-58204
Here ya go! :thumb:
Quieted down my FJ80 nicely. Then water got in through a broken breather tube and I haven't been able to say if the improvements were going to be long term.
...so there is a serious question in all of this...
If you manage to silence the WOOOB WOOOB WOOOB mechanical gear noises, the chattering, and even that irritating stutter you know is binding by swapping out for a better/thicker oil...
Is the stock stuff that comes with our trucks, cars, motorcycles really that crappy?
I don't use the shockproof but I do use the redline 75w90 ns and it's very smooth. I put it in both diffs and the transfer case. I bought 9 quarts of it a while back. I think I'm down to 1 full bottle left. For those of you with full time lockers though I bet the heavy shockproof works well.
I have the Redline GL4 in my trans and it does a much better job than the modern GL5s. I think next time I do my rear diff I'll try this new stuff out.
