RIGID Radiance POD XL - Now Available
RADIANCE POD XL - CLICK HERE
RIGID Radiance lighting family just got better with the introduction of the new Radiance Pod XL.
Boasting the same quality LED technology and Broad Spot Optics as the Radiance Light Bars, the
Radiance Pod XL packs plenty of output in a compact package. Similar in design and shape to the
popular D-XL PRO, the Radiance Pod XL measures 4” x 4” and includes a blacked-out circuit board
for a subtle, more refined look.
Our custom designed graphs are intended to illustrate the beam patterns that our optics produce.
First, consider what type of application the light is needed for and then choose what beam pattern
best suits your needs. Each beam pattern varies depending on the optic or optic combination you
choose. Once you know which beam pattern best suits your needs, refer to the specifications table
(A, B, C) to determine how much LUX output you need and which product will suit your application.
FEATURES
• 50,000+ Hour Lifespan
• 10-15 V DC
• Durable UV Polyester Powder Coat
• Pressure Equalizing Vent
• Harness (Sold Separately)
• High-Grade Aluminum Alloy Heatsink
• Integrated Thermal Management System
• Impact Resistant Polycarbonate Lens
• IP68 Compliant – Dust / Water Ingress
• Mounting Brackets Included
• Over / Under Voltage Protection
• Operating Temp -40º F ~ +145º F / -40º C ~ +60º C
• Protected Against RFI / EMI
• Patented Technology
• Reverse Polarity Protection
• RoHS Compliant
• SAE J575 Compliant – Shock / Vibration
• D-XL Series Construction & Durability
• Complete Multi-Switch Wiring Harness
• Independently Controlled Back-Lighting Available in White,
Amber, Red, or Blue
• Dedicated Wire to Run Back-Lighting without Primary LEDs
• Stainless Steel Mounting Brackets
• Black Exposed Circuit Board
• Patent-Pending Technology
For a Complete List of RIGID Radiance POD XL Lights - Click Here
_
2001ATL
