rim size 3rd Gen
Wheelin
Can you put 15'' rims on a 3rd gen t4r?? I know of issues with rotor size on the 4th gens i think.... also what backspaing would be good for a 31 or 32'' tire on a 15'' rim if they do work.
Dave
I could be wrong but i belive if you have 15" rims OEM then there shouldnt be any problem. Some 3rd gens came with 16"oem rims in this case you would need a 16" or larger rim.
-Matt
there may be problem with the brakes... the calipers? i cant remember. but there is something you need to change there...
It's not that 15" rims aren't a good idea, you just need to do some research. If you have the OEM 15" aftermarket 15" will work fine. Like other members have said the rotor size and position of the caliper will not allow 15" rims if the OEMs were 16"
**Best bet is to get 16" or larger rims**
just my 2 cents
-Matt
