Robb235's Front Mount Turbo Build
Sorry that my family and career got in the way of your reading pleasure.
That's no excuse! Turbocharging an old Toyota is much more important than family! And the military?? OTS? What a waste of time when you could be tuning a turbo. We don't need a military. We already have fantastic world leaders in place like little Kim, Vladimir Putin, and Bashar Assad
One thing I debated was whether or not I should coat the inside of the manifold, or coat the outside only.
Ultimately I decided to only coat the outside and not the inside. I don't know that I trust this stuff enough to not flake off and go through the turbo..,
So did you ever get a chance to cure them? also I have the CXracing manifolds, been on the truck for about 3 months now and havent had any issues except the gaskets which literally blew apart, but I got a new set from FEL-PRO and they have been working like a charm. also if you ever get that puppy built, your stock ecu and fuel system will be fine running up to 5 PSI depending on your elevation. there is a guy sitting at a mile high that runs 8 PSI with the stock fuel system, whereas mine anything past 5PSI the engine starts to detonate because it goes lean, so needless to say I need to do some more modifying.
seltzernator
