Roof rack options?
Bml_merris
I have a 1999 4Runner with the factory roof mounts that run along the roof, but am missing the cross sections that go horizontally. What are some good roof rack options that aren't too pricey?
Sent from my SM-G930V using Tapatalk
I personally like the factory cross bars. On my older 91 4runner I went to a toyota junk yard and got the entire factory roof rack system. I don't remember what I paid but it definitely wasn't much. It might be harder to find just the cross bars at a junk yard though.
I like them too but I was thinking about going with a roof basket style setup because it is more readily available.
Oh gotcha. Yeah I don't know then, I'm in the same boat. I ended up getting a cheap no name brand roof basket for my last 4runner but I won't go that route again it ended up rusting quickly. I guess I'll be following this thread for some ideas myself!
I have heard of problems with the Curt racks rusting pretty bad. Do you think a layer of spray paint over everything would fix that issue?
I have a Thule Tracker II rack on mine. The cleats for the risers mount very securely to the factory rails and the risers and bars clip on or off in seconds. Here in Wisconsin I leave the bars off in winter when not in use to avoid corrosion. During spring, summer and fall they are always mounted up (and locked on with Thule lock cylinders) with my kayak and canoe saddles. I also have a Thule roof box that rides nicely up there. They handle a heavier load than the factory bars and the accessories swap easily onto my 87 VW Westy or my wife’s 05 Outback. I picked them up on craigslist for a decent price and could sell any or all for what I’ve paid for them.
I'm in Seattle and have factory crossbars you can have. LMK.
I've heard the water gets inside the tubes and then sloshes out all rusty.
I put a lot of heavy weight on my rack, I put a 24' and 32' ladder stacked all the time, heavy wood, etc. So I've doubled up my factory rack to hold 4 cross members. I've stuck some serious weight up there, pushing it's limits. Roof still intact.
Sent from my SM-N920V using Tapatalk
That's an interesting idea, never thought about that!
I'm not that keen on the stock cross bars. My wife has a Thule rack that attaches to them. Once on an extended overlanding trip with some weight up there (Canyonlands Maze District) one of them bent and collapsed. She doubled them up after that - 4 cross bars. Then another time, even with all 4 bars she came down off a steep ledge and bumped the car pretty solidly (on Black Bear Pass) and all 4 cross bars let loose and the whole thing slid out the front, skipped off the hood, and landed down the trail a bit.
I put a Rola rack on mine, it's a little sleeker looking - nothing to grab or snag on trees sliding past (I've inadvertently used it as a 'slider' before - leaned the top over into a tree leaning over the trail). Instead of using the stock crossbars I just made some mounts using Unistrut sections from Home Depot. Cut them in sections, drilled some holes, bolted them into the channels, and bolted the rack to them. It seems a lot more solid and sturdy - if you really yank and shove on the rack the only thing that budges even a little is the roof itself. And it sits down closer to the roof so it looks less bulky. Here are some pics from an earlier thread: http://www.toyota-4runner.org/3rd-gen-t4rs/173293-attaching-rola-roof-rack-2.html#post1748870
FWIW the Rola rack is pretty cheap, but mine did rust after a few years up on the roof. Last year I finally got fed up with it enough to take it off and spend a while wire wheeling ti and rattle canned it black again. Also, drilled some drain holes in the front and back ends of the rack where the bars droop downward, I found that in wet conditions they'd gather water, which would get rusty, then when you'd go wheeling and tilt the car into unusual positions, the water would come out of the ends and past the junction in the middle (it comes in 2 pieces) and pour rusty water down the side of the truck.
The Rola rack is a great option if you don't want to spend a ton of money. I did a similar mounting technique to yours, but I used two pieces of aluminum angle bolted together, then attached to the factory rails. It seems very solid.
One thing I did do to try to prevent rust is bought some black silicon and put it on the separation pieces and on every bolt hole I could find. I also replace all of the hardware with stainless steel screws. Wipe everything down with T-9 oil every now and then and it should keep it rust free fro a while.
Yeah I like the way the Rola looks, very stout and low profile. And decent price too. And good idea with the silicon I imagine that would at least keep the water out of the internals which is where my last one was rusting
I have the stock rack and the Yakima attachment that goes with the stock rack. I like them. Selling the truck but can part with the rack if you like.
I like the Baja standard basket but I might want to haul some plywood and the basket is curved. I wish it was flat. Anyone haul plywood or flat items with it?
That's why I went with the Baja utility rack over the standard basket
You'll have to add some crossbars
Thule roof rack for 2018 4runner with moonroof
Hello everyone,
I'm sure someone on here has put a Thule roof rack on a 2018 4runner with a moonroof. Which bars did you use, square or Aerobars? Did you need a fairing? How was wind noise? I want to put a Thule cargo box on it. What the largest one that will fit and not interfere with the moonroof and still be able lift the back gate all the way up? Any other helpful hints on this? It will be close to a $1000 dollars for the rack and box and it will likely last the life of the vehicle so I want to get it right the first time. Any advice is appreciated.
Jeff
MaximussK
