Rough Country 30 inch led light bar- roseville, ca
trailstandardoffroad
official vendor
I have a like new in box led lightbar. It is from rough county. It is thier black series 30 inch curved light bar. I just paid $250 for it last week. It is too big for the place want to put it. I welded on 1 inch risers to the minting brackets so they wont let me return it.
I have tested it and it does work 100%. Comes with mounting hardware and wiring harness. It's a really nice light bar. Wish I could keep it.
Part number from rough country - 72730BL
Rough Country 30-inch Curved Cree LED Light Bar Single Row Black Series
Description
Command the Dark: Stay out later on the trails with Rough Country's low-profile 30-inch Curved Single-Row CREE LED Light Bar. This sleek, slim-line single row light bar offers enormous lighting power in a stylish, modern frame. With a powerful 12,000 Lumens and 150 Watt output, Rough Country's 30-inch Curved Single-Row LED light is a sight to behold.
Rough Country's LED Light Bars include a durable die-cast aluminum, IP67 waterproof housing for unsurpassed protection against the elements. Each LED also features a premium flat-wound, braided, IP68 waterproof wiring harness with a toggle switch and in-line fuse. Tired of wind noise? Each 30" Curved LED Light Bar includes a set of noise silencers to eliminate harmonic vibration caused by wind hitting the light during higher speeds. For peace of mind, each LED also includes Rough Country's 3-year Warranty.
Features
12000 lumens
150 watts
Contains 30, 5 watt Cree LEDs
Durable die cast aluminum housing
30 degree spot beam
Black panel design
IP67 Waterproof rating
Moisture Breather technology reduces moisture build-up behind the lends
Includes premium, flat-wound wiring harness with on/off switch
Includes Noise Silencers to help eliminate hum, whistle, and other wind noises associated with mounted LED Light bars
3 year warranty
Length: 31.37-inches | Depth: 3.12-inches | Height: 1.6-inches
Bolt Diameter: 8mm
Specs
Install Time: 2-3 hours
In the box
30-inch Curved LED Light Bar
Wiring harness
On/Off switch
Hardware
Notes
For off-road use ONLY
Asking $150
Jhunt
