safari bar installed
tips
for those of you considering buying the westin bar, i strongly recommend that you go to a hardware store, and buy 2 x 1 and 1/2 plumbing stoppers .(the bar is 2 inch diameter so this size fits snug). place these on the end of the safari bar, and cut a a hole in each one to allow the screw to go through. then attach it to the mounting brackets - otherwise, it will be metal on metal, and the paint may chip making the bar succeptible to rust. i also dumped a quart of oil in the bar, and shook it around in there for a bit to coat the inside - my last brush guard rusted out in 3 years.
Oh man definetly put those PIAA's on. I would have gone with that if I was willing to spend the money. Instead I went with a cheaper foglight, and going to keep the safari bar black. But yet, wire those babies up and light up the street.
ya i may just spend the money and get them...but i would probly paint the light covers to match the paint....you have any pics of your rig?
Many have asked that question. Well it basically looks exactly like yours without the bar and lights. I yet to get the bar, I have the lights but it makes sense to wait for the bar before installing the lights. Once it's all done I will post away.
I got the safari bar but I have a problem
Lloyd, who installed that for you or did you do it yourself? If you did you must have a Impact Wrench powered by an air compressor.
Dude I took to it a wrench, socket wrench, and a crescent wrench and the only effect I had is stripping the bolt (a little). I learned where to stop from previous experience. I had to call my buddy who is a transmission guy to make arrangements with him to get it on a lift and removing the bolts for me. The damn things won't budge.
I am set to meet him this Tuesday: but I see it's an easy install if you can get the bolts removed. Keep in mind these bolts are part of a set of bolts holding up the bumper: I am not surprised they are a pain to remove.
iman....ya those bolts were a pain in the a$$....i didnt think id be able to get them off, untill i got a longer ratchet so i could get some leverage on them....first makesure your turning them the right way....i was trying for a bit b4 realising i was going the wrong way....like i said if you have a longer ratchet, youll be able to move them...it took a while too as the more they come off, the less room you have to work with....but it can be done i did it within an hour....if you need more info let me know...good luck!
It's done, but after all the time I spent planning back in November to now, a lot did not go as planned. Before I post the pics here are the following facts of my plan with the safari bar.
As any of us know, the 4 Runner comes with fog lights, but me I just can't leave it at that, I need to add more. So I spent about a month thinking about lights and how to mount. I finally decided on the safari bar. What I learned about it, as easy as the installation should be, depending on what tools you have and the leverage, and can be a real pain. But once installed it's perfect.
Then came the lights, which my first instinct was to get PIAA (I should have stuck with that decision). I discussed with many people, and got a lot of great help from "Good Times". But not sure if it was Good Times or someone else, but I decided on a name brand fog light I never heard of but liked what I saw and that is "Lightforce". People, what you may not know about these lights, is due to the design and how the Safari bar is positioned, it's a bad mix: really bad mix. Once I bolted one light on, I realized I could not position it up for the angles that the plastic is molded to, and how it's positioned on the Safari bar I just could not do anything with it. Thank god I got the okay to return it and will be doing that this coming Monday. So here I am today with my buddy to help install fog lights that suck for my purposes: so we head to Pepboys to see what they had. On the way I went to the town's local auto parts store and bought a pair of no name brand fog lights for $30 bucks (paid over *$170 for the Lightforce). Well the directions stunk, and the installation was anything but easy: so including the time discussing if I should get new lights, the trip checking them out, purchasing them, coming home for the installation: well we started at 10am and finished at 4pm (give or take a few minutes).
But now I have my safari bar and really cute lights. The only thing is that they are not as bright as I wanted them to be, but since I have all the wiring done, if I ever want to upgrade the installation I know will be a lot easier.
What I learned out of all of this is that the big lights are no always the way to go. A lot of people say it makes the car look like a fly: I know that is true for some vehicles because that is exactly what my CR-V looked like. Anyway, I am happy with the install except, the installation of the button was not a simple pop it in. The damn thing would not fit, so I ended up using my Dremel to shave the sides down, and then using some elbow grease I got the button in. Besides the car being dirty (hey, it gives it character) the final product put's a smile on my face.
So here are the picks I have been asked for many times.
YIPPI!!!
I think the car looks better at night.
You would never know by looking at it, that I sanded that hole that the switch is in with a dremel unless you remove the switch.
hey iman...looks great....so what lights did you decide to go with...seeing the lights installed makes me wanna put them on now....but i can see how you need lights that can be angled up, as the brackets on the safari bar are not parallel to the ground - slightly angled towards the ground. this forum is killing my bank account!!!:50cal:
Honestly, they are a no name brand. Like I said earlier the lights I was going to go with, due to the design and the position of the Safari bar, they were just not a good choice. So I ended up going with those small low profile style lights.
You guys ( Iman74 and loyd) should have never posted those pics. They look great. Well, I know what my next mod is going to be :) And the bug deflector looks great too!!
Update...those lights are coming off and I am replacing them with PIAA's.
Piece of advice everyone: do not let emotions or finance get in the way with what you really want. If you really want PIAA then get it: if you can't afford it, do not get anything. This is a lame replacement for something I couldn't get at the time of the planned install. Now I have my new PIAA's on the way, and from what I hear, I might have to rip out the wiring I spent half a day doing so nice and neat for this. If I do not have to do that, great. But if I do, man that's going to suck.
ya thats what i figured too - i want the pias, but they are exoensive and theres a few other things i want first - so im just gonna wait - thanks for the tip cuz i almost bought some cheap ones
i have seen them on a few - and they do look good - but i dont think id spend the money as id proble never use it
ghengiskhan
