saggy rear
grokglock
I{ was towing a trailer this weekend and I can no longer avoid how bad my rear suspension is.
I know there are threads on tundra and Tacoma replacement parts that will lift the suspension over stock.
Can I get a parts list to upgrade the rear suspension?
Do you really want to lift just the rear or do you only not want it to sag out when towing a trailer. If the latter, air bags are an easy and excellent solution.
My rear suspension is shot need to replace might as well upgrade a little can tundra springs be used?
I would get a set of OME 906 springs. They are excellent for towing and will give you a mild 2" lift in the back. You will have a little rake but nothing crazy. A set can be had for $180ish bucks.
You'll want to replace your shocks while you're at it. Lots of people like the 5100's.
seltzernator
