Seized camber adjusters
Jb973
Hey guys, so went in to have my alignment done after installing my lift, and of course the camber adjusters have frozen solid. I've just used the search and read some threads and almost all said that I would need to purchase new adjusters strait from Toyota . So I did a Google search and saw that moog makes a camber adjustment kit, I'm assuming that is what I need? Along with new bushings. If any one could give me some info, I would appreciate it . Thanks
Front Moog bolts work, rear ones were too long for me. I ended up purchasing Toyota bolts to replace the rear ones.
It's likely you'll end up having to replace the bushings as well. If you live in a climate that sees cold weather, I would avoid the polyurethane bushings that everyone seems to recommend. If not, go for it.
It's not a fun task to do yourself, and not cheap if you pay someone to do it.
mek
