Seized Spark Plug
texadelphia
Changed my plugs today and the 3 on the passenger side were all really tight coming out. I couldn't get one to budge. It would turn a couple turns and then just bind up. I'm planning on hitting it with penetrating oil and kind of loosening and tightening it to work the penetrating oil in. Anyone have any other suggestions?
I'm not a plugologist or anything, but I change mine every 2 years. I'd first try the penetrating oil just as you are planning to do. Good luck.
Thread it back in, install the other spark plugs, run the engine until it’s at operating temp then try to take the spark plug out.
When it turns, does it turn freely? Or is it gritty feeling? I'd soak it in PB blaster, but also trying to remove it after running the engine to operating temp sounds like a good idea too. Maybe some dingus installed that plug when the engine was hot.
It feels "squeaky" when I try to back it out like it's binding, no grittiness. All three on the passenger side felt that way but I was able to power out the front 2. At first I thought they were cross threaded but the new ones went in easy.
I'll try the operating temp thing and then hit it with penetrating oil if that doesn't do it. If I get it out should I let the engine cool back down before reinstalling?
I'd start with your plan to soak it in penetrating oil and then work it very slightly back and forth.
Spray, wait and repeat.
Just went through this on my town car. I did it with the motor cold.
It has aluminum heads.
I agree that moving is a good thing. You get it just work it slowly..:)
Sent from my SM-A505U using Tapatalk
Sounds like you are being careful which is good, not an area you want to have problems.
As spark plugs are cheap I change them out frequently to avoid any sticking issues.
I mostly just anti seize them and never have issues after that myself. :)
I've never felt comfortable with anti-seize when the plug manufacturers don't recommend using it and lubricated threads and dry threads have different torque specs.
Valid point.. However, I don't torque spark plugs. I snug them until they crush the crush washer and use a small handled ratchet to tighten then up. you have to drop the torque spec 25% if using anti seize.. If you don't your will over torque things..
With aluminum heads I use a 1/4 drive and an adaptor.
Sometimes if the spark plug wasn’t sealed in the head the gasses and carbon can creep up 3-5 threads and really make it a bugger to remove.
In order for penetrating oil to work the plug needs to be backed out a thread or so.
The Denso plugs I used didn't even have a torque spec. Instructions said turn 1/4-1/2 turn past initial contact.
I been anti seizing them for years.. I just tighten them down and that is it..:-)
No torquing required at all. Maybe the anti seize keeps my threads clean..
This is just how I been doing it for the last 33 years. You can do it however you see it fit for you. No problemo :-)
I believe the torque spec is either 13 or 14 foot pounds, though I would do some research first. I think I saw that in the FSM.
Sent from my SM-S908U using Tapatalk
Steel threads into aluminum mostly are always less the 15ft pounds. Just like the valve pan gasket torquing. :)
