Shark fin antenna separated at rear from roof - Solutions?
boyfester
I just noticed my 2014 TE antenna has separated from the roof. Any solutions?
i just picked up an 11 that has the same problem! i think mine was hit as well since there are some scrapes on the "spoiler".
I did that to mine when I smacked my roof-top box into it. I pushed it back down but it would not stay. You could try pushing it back down and tightening the nut that holds it. I solved the problem by replacing it with a low-profile version. This thread will explain:
http://www.toyota-4runner.org/5th-gen-t4rs/215885-low-profile-xm-shark-fin-antenna-swap.html
How do you access the "nut" to tighten? Is it under the plastic fin cover?
One has to pull down the headliner at the rear. Remove the snap buttons, carefully pull it down a bit, and reach in there and tighten the nut. It is a tight fit, take your time and you will not crease the headliner. As stated above, this did not work for me, the roof metal was bent a bit right at the spot where the nut goes through the roof. You may have done the same thing. I flattened it when I installed the low profile antenna. You may have to remove the antenna nut, lift the antenna, and bend the roof flat as I did.
4funnr posted some good instructions:
http://www.toyota-4runner.org/2717528-post112.html
So I tightened up the nut and nothing happened. I have now realized that it is the antenna gasket's adhesive that has caused it pop up. The roof line isn't bent. I added some Liquid Nails between the gasket and roof and put some wood on top for weight. I'll let it dry today and check it tomorrow.
PRWhite
