- Sherpa Equipment Co. -
Truck Brigade
Sherpa Equipment Co.​
With so many Roof Rack options on the market today, how can you be sure you are choosing the option that will best serve you while on the trail? While every person's needs are different, Sherpa Equipment Co. has put themselves a step above the rest. From the designated trail to the uncharted, Sherpa Equipment Co. has a rack that is ready to take the path less traveled. Whether you need a rack to store all your gear, including a roof top tent, or just a rack that is built to last for years to come; we are proud to be an authorized dealer for Sherpa Equipment Co.
Sherpa was founded and continues to be based out of Colorado; where their Roof Racks have had to endure everything that the Southern Rockies could throw at them. With a testing ground as diverse as Colorado; you can be sure that each and every Sherpa Equipment Co. Rack is built with quality in mind. Sherpa Equipment Co. derived from a need to haul all the gear the founders depended on. Sherpas Equipment Co. racks are tested, field proven, and designed to maximize the potential of your Rig.
This all means nothing though if there is not a team that stands behind the product. The passion that each rack has been designed with carries over into how each rack is fabricated and shipped. This same passion is shown through the continuing innovation at Sherpa Equipment Co. Built by those that love the adventure of the unknown or for those charting a new path of their own; you can rely on Sherpa Equipment Co. be ready for the journey ahead.
With Sherpa Equipment Co. roof racks, adding a rooftop tent, cargo boxes, awnings, fuel and water containers, kayaks, bikes, and much more can all be mounted with ease. There’s also many different light mount locations on these racks, which means the possibilities for lighting are almost endless. From scene lights to chase lights; forward-facing light bars to pod lights. Sherpa Equipment Co. racks make sure your offroad adventure doesn’t keep you in the dark. How else are you going to catch Bigfoot at night?!?
Built into each Sherpa Equipment Co. racks are “hand-holds” that make accessing gear easy. Having to grab a solid aluminum rail without cutouts can be dangerous and uncomfortable. So, it is important to have areas that you can tightly hold onto. With some racks you have to get aftermarket handles that cost extra, the Sherpas Equipment Co. has pre-cut out hand-holds that don’t jump out from the sides, so the wind noise won’t be increased, and you won’t have something hanging off the side of your roof rail. Sherpa Equipment Co. also makes adapt plates, that provide extra surface area for mounting your offroad accessories and can double as a platform for your rack!
Another HUGE piece about Sherpa Equipment Co. that sets them apart from their competition is their mounting design. They don’t require, and actually recommend against using, silicone. Instead, they designed their mounting feet with rubber roof seals. The rubber mounts are designed to create a seal similar to what the factory rack does in order to keep everything dry. Also, many racks out there require you to move your XM antenna, or change up the configuration of their crossbars, not Sherpa Equipment Co. Their rack systems accommodate and protect it!
Sherpa Equipment Co. delivers an impressive and industry leading 1/4" thick aluminum rail on each side of their vehicle specific roof racks. This provides a lightweight and durable rack that weighs in at 55 lbs or less, while still being able to haul an impressive 300lb dynamic load (and NO we are not recommending you put your screaming kids or mother -in-law up there!!); but when you are camping, you and a few others can get up in your rooftop tent because it can hold 700 lbs. when the vehicle is not in motion.
Oh yeah, we almost forgot…most applications feature a “no-drill” installation.
It’s easy to see why Sherpa has become a staple when leaving the world behind. This is why Sherpa Equipment Co. may be the next (and last) rack for your Overlanding Adventure!
seltzernator
