Shrockworks front bumper and light bar install issue
EEtM33t
I have a Shrockworks front bumper and I want to install a 20" Baja Designs light bar on it. Anyone here do that? If so, how and where did you mount it to the bumper?
The bottom of my grill is too far forward when the front bonnet is raised preventing me from installing the light bar under the center hoop - which is where I wanted to install it... If I install the light bar onto the bumper under the center hoop, the back of the light bar will be hit by the grill anytime I open the front bonnet.
Thanks.
I tried every which way to fit my light bar under my center hoop. For about a year I ran no front grill to avoid the interference of the light and the grill but it leaves your radiator, and associated a.c. stuff very exposed. My final solution was just cutting the grill where it was hitting. I like the setup but just depends if you are willing to cut your grill or not. I'll try to grab some pictures later and post them.
Behind grill? On roof rack? Have a shop cut a slot through the front of your bumper and weld tabs on the inside to mount it flush to the face of you bumper but hidden inside.
Photos would be great, thanks.
I would not mind replacing my grill with a Satoshi grill and then mounting the light bar behind the grill...I just need to find someone who makes Satoshi grills...then I'll need to find a local shop to do the light bar install...
