IronManKansas
Now I am waiting on my 2014 trail rocker panel to do my rocker conversion:guitar3:. Really should have planned that one better. What's another 2 weeks...
A suburb called Overland Park.
For the guys that installed the sliders already: both sides require unbolting the gas tank or just the driver side? I'll be installing mine tomorrow so I wanted to prepare myself.
Looks like just the driver side to me. I unbolted the skid plate only on the driver side and you can access the gas tank strap. No need to unbolt the gas tank![]()
Got my sliders and I'm attempting to install the driver side now. I'm stuck on the rear mounting plate (side of frame).
Got the gas tank strap back in. Damn that was a pain the ass! I ended up using a spark-plug socket extension to push against the strap to push the weight up so I can get that sucker in. Took me like 30 freaking minutes :lol:
Anyways I read the instructions but it seems the mounting holes (again rear mounting plate against the side of frame) doesn't seem to screw into anything. If I am suppose to use a stick-nut, I'm not sure how to go about it there.
Anybody else run into this dilemma?
Update:
OK so definitely need to use the stick-nut but I don't see an access point to get behind the frame.
You'll need to pop off one of the plastic covers on the frame. Should be an access point close enough to get to the mounting point.
Maybe the wrong place to ask this question, but for those that use their sliders as jack points, are they "bolted on" or "welded on"? Would these be strong enough to jack up with while "bolted" without any issues?
MIne are just bolted on. I had the truck supported on one wide with two jack stand under just the slider. No problem.
Also, sliders paid for themselves yesterday when a genius in a honda civic pulled out of a parking spot as I drove by. Slid right over the front corner of the civic and didn't even scratch the powder coat. Honda driver gets to buy a new front bumper cover etc. Yeah for parking lot protection.
On an install note: Do y'all leave the long tab for the stick nut sticking out of the access hole or did you break them off and put the plastic plug back in?
I have finally installed my front and rear Shrockworks bumpers. Very happy with looks and function. Today was the shakedown run and everything went well with no problems.
