Slow Starter Issue (power issues)
Justfuzzit
Searching, can't find answers. Please post them if I missed anything!
2000 Limited 3.4 V6
My issue... Starter is super labored sounding, slow like it's not getting enough power. Once it turns over, it's usually ok (now that I fixed the rubber bumper under the cable head at the gas pedal... it blew up. Not sure why that fixed the starting issue). But the slow, labored starter is the remaining issue. And that everything in the car seems to have low power.
- Started about a week after having an injector replaced
- Windows crawl up slowly when the car's not running
- Lights dim at low rpm
- Battery and alternator check out ok at Autozone, but battery was at 30% (I know this isn't a 100% test)
- Battery terminals are clean and no corrosion on wires
- The grounds that I can find look ok/connected
- Tried starting in "start mode" with battery charger which changed nothing
- Fuel pump and filter replaced
- Fuses look ok, but haven't pulled anything other than the little guys
I appreciate any help I can get.
Jhunt
