Smittybuilt 5.65 CFM compressor cheap right now
Can't say enough good things about the PUMA PD1006.
Puma PD1006 3/4-HP 1.5-Gallon 12-Volt Continuous Duty DC Air Compressor
A little more money but having ran the ARB CKMA12, two separate ARB CKMTA12, and an old MV-50, the PUMA can't be beat for the value. It's as quick (or very very close) airing up 35's as the ARB twin and it's less than a third of the price. Still 100% duty cycle as well. Only downside is it's size but you can split the tank if it makes sense to mount it that way.
I don't know about that. I personally know several people with these larger ones that have had them years with no problems.
I almost bought the Smitty but most of the reviews on a 4x4 site said they died after 3 times and the warranty was useless. It look like the Hong Kong Freight model is the same. A lot of people in my friends Jeep club use the Tsunami Air on 35's and it's cheap.
12V 150 PSI Compact Air Compressor
MasterFlow Tsunami MF-1050 12 Volt Portable Hi Volume Air Compressor MF1050 | eBay
mine is 5 years old now. still working great. the only real issue, the filter cap doesn't like to stay on. it would be a simple fix, if I cared to mess with it.
the master flow is closer to the smaller smittybilt pump. a bit less than half the output of this large one.
What's this about them getting extremely hot?
compressed air is hot. they will all do that. you wont want to touch the metal part of the hose, where it comes out of the compressor after airing up 4 tires. it will burn you.
that said, I have many times filled up my 37's, and 42s, and have yet to need to stop so it can cool down. it puts out so much air, the tires are up to pressure long before the pump could ever overheat.
yep they get hot. really hot. Pretty sure this one has a thermal cutoff. as to protect the unit from overheating and burning itself out.
Ah got it. Thanks for the clarification guys.
Is this unit a good choice to mount under the body or would a different one be better for that?
not sure if they are waterproof.. but I have heard of people mounting them under the hood. to each his own.
Great price: maybe get one so I don't have to switch my VIAIR back and forth.
Yes, these things get hot, moving parts, electricity, and compressed air does that.
I kinda want two of them... put them in parallel for very fast tire fill speeds.
I found such a beast a few years ago. sold out of Australia. it was only around $100 USD. but, total to get it imported to the states was going to be closer to $600. so I scrapped the idea.
it was essentially this same compressor, except it had another pump head on the other end. it was rated at basically double of this one, 11cfm or so. crazy!
Sounds like they utilized a single motor with two pistons to increase the volume?
I still like the idea of two separate units, it provides fault tolerance should one ever fail.
Sometimes one is none.
Ambrose67
