So here is how cleaning my IAC caused it to start acting up (I won't call it "fail", because it is still perfectly good, it just needed some additional resuscitation).
I used Timmy's video for guidance (
IAC Valve Testing and Cleaning - YouTube) and was really careful to avoid dousing the inside of the IAC with solvent, worrying about the delicate bearings. I just cleaned the rotating barrel with a q-tip soaked in solvent.
After that, I ran the opening and closing tests as per the video (and FSM). It did open fully when commanded to open, and rotated into the closing direction when commanded to close. So everything seemed good to go.
So in my autopsy, I again looked at the rotating barrel. Here it is in the normal room temperature position:
You can see that there is a small window opening allowing air to pass through the IAC. To check for freedom of motion, I inserted a small screwdriver into the opening, and rotated the barrel towards the open position - it rotated easily:
So again, I thought everything was good.
Here's the thing though - when the IAC is assembled, it is nearly impossible to manually rotate the barrel into the
fully closed position - there is nothing to push on. So I had to go by the closing test in the FSM and in Timmy's video. And just like in the video at 35:30, when I applied power in the closed direction, it started rotating in that direction (I'm using the words "started rotating" very intentionally here). But just like in the video, the opening didn't fully close, it just moved in that direction.
Once I had the IAC apart and could rotate the shaft by hand, I noticed that when trying to
fully close the barrel, there was a sudden added resistance. I gave it a bit more torque, and finally saw the culprit: there was a layer of carbon on the barrel, preventing it from closing fully:
So what happened was that my q-tip cleaning dissolved the carbon, but the carbon then reconstituted itself on a different portion of the barrel, and once it dried, it prevented the barrel from closing. Without taking the IAC apart, I couldn't rotate the barrel far enough to notice this, but the actuator didn't have enough torque to overcome the resistance.
I haven't tried it yet, but I will clean off this carbon and reassemble, and I am confident that the IAC will work perfectly.
So my takeaways are:
1. Don't clean the IAC unless you have to! Mine was working perfectly fine before, and I could have left it alone.
2. If you do clean the IAC, be sure all the carbon is actually removed, not just moved around. Try to find a way to move the valve FULLY to open and closed positions, to make sure there is no carbon left anywhere.
3. Don't clean the IAC if you unless you have to!
Hope this helps others! And Timmy, in no way am I criticizing your video, it is a great service to the community. I just wanted to add the comment that it's critical to get ALL the carbon out, and to check for FULL closing and opening operation after cleaning.
