Something weird just happened w/ my ABS on hill
AUSig
I was just leaving a shopping center and something really strange happened. I was stopped on a hill, somewhat steep but nothing crazy, and when I went to accelerate I just rolled back and the ABS brakes started clicked. I hit the brakes and tried again and the same thing happened. There was a car right behind me at this point so I gave it a decent amount of gas and was able to pull out. Why would this have happened? I had a 100 series before this 4runner with same engine/transmission and have never experienced anything like this before...
Before someone asks, this was 100% dry pavement. No way any of the tires were slipping. I dont know much about atrac or vsc, but there is no reason it should have engaged.
Sounds like the Up-Hill Assist was trying to kick in. Its like Downhill-Assist Control but it works to keep the vehicle from rolling backwards when climbing hills. Most people never activate it/get it to happen, its one of the subtle features the 4th gens got (I believe it was carried over to the 5th gen as well) I don't remember if it was ever mentioned in the owner's manual.
I'm a little surprised that your V8 even rolled backwards, I don't think mine has ever rolled backwards even in San Francisco's hills; the torque from the V8 combined with the torque converter stall speed usually means I can just sit at a red light on a hill with my foot off the brake (though if I give it a bit of gas it starts to creep up by itself. :) )
Man I can already tell I'm going to hate the electronics on this Runner once I start wheeling it. My 3rd gen didnt have any of that crap. Is there a way to disable uphill assist???! If it was uphill assist trying to help, it made it worse, I rolled back 3 or 4 feet before I could get it to move forward!
Thats why I was surprised too, I just got this 4Runner 4 weeks ago and it definitely has a very strong idle creep (how do you phrase that?)
I don't have an answer for the OP but I've had my Up-Hill Assist engage many times but all have been off-road.
I came from an '88 Land Cruiser and the electronics were hard to get used to but now I love it off-road. Give it time and learn how it works to use it to your advantage.
I know it work for up or down hill, great when off roading in my experience. Easier than having to ride the brakes.
Hated it at first, but, love it now.
Hill-Start Assist Control (HAC) is a standard feature on 4th and 5th generation 4Runners, designed to assist the driver on a steep incline. The system utilizes electronic sensors within the brakes to detect when a wheel or wheels are slipping, then gently applies the brakes. This allows the driver time to engage the accelerator, thus helping to prevent a precarious backwards roll.
+1 for the hill start assist.
Once you get used to the doodads I think you'll find you like them.
e.g: This winter, on a school snow day, I took mine to the nearby high school parking lot to play around on the slick surface and go through all the modes and get a feel for how the ABS and handling respond during poor traction. I'll say that with 4wd engaged and the abs/ traction control engaged I had to try hard to make it slip and spin out, and even then I couldn't get it to spin much. The traction control system is very effective. I gave me a lot of confidence that anytime I need to drive in snow that the truck will perform well (so long as I don't do anything stupid or the other yahoos out and about). I commute 50 miles to work and I've gone the whole way in fresh snow (the firemen have to get to work, you know). I hadn't had any opportunities for that kind of driving yet since having my Runner.
Also, If you lock your center diff. it will de-activate the traction control for times off road when you don't want the abs kicking in for traction... It's a good system.
Honestly for the most part the electronics are really well done in terms of off-road capability. There really hasn't been that many times I have felt the electronics really limiting me off-road, typically only in mud (because of throttle cut-off for the TCS), though I will have to make an "Off-Switch" for them one of these days.
I'm a little surprised that your V8 even rolled backwards, I don't think mine has ever rolled backwards even in San Francisco's hills...
Didn't you say once that your HVAC has basically one position -- max cool?
I think that explains it.
I recently did a little test off road. Sitting on a 17 degree hill in low range with AC on, the truck held easily. Turned AC off, instantly started rolling backwards. Those couple of hundred rpms make a big difference.
That's very true... I almost always run the A/C, so I probably never noticed otherwise, will have to try that next time I'm in San Fran. :)
Jhunt
