SSO Slimline Bumper light bar
SteelStacks
So I’ve finally decided to Install my SSO bumper that’s been sitting in my garage for a couple years. Problem is I don’t remember ever getting instructions for the 20 inch light bar install. Looked everywhere on the net and can’t find anything. Can anyone here help me out.
Light bar came with a bunch of bolts and brackets but I guess I don’t need them all. Is it just 2 bolts and washers that I need to use? Also bolts seem too long. Would love some clarification or a detailed write up if possible. Thank you.
Yes, the lightbar came with several mounting solutions but the bumper already has tabs on the inside. You loosen the bolts on the sides of the lightbar, slide the bolts into the tabs, rotate the beam to your preference, then tighten up the bolts.
The rest of the stuff in the box is just stuff that came with the lightbar and not from SSO, it is used for several different mounting options.
If you need help holler, I'll try to get some pics.
Thank you for the quick response. Used the 2 bolts and washers and fit perfectly. Guess sometimes the easiest answer is the right answer. Now to attach the winch and install the bumper.
So finally got the bumper installed with winch and light bar set up. Did it myself and took forever to jack up the bumper and align the bolt holes because it was so wobbly on the jack.
Anyway, seems like the bumper is off center a bit.
Is the driver’s side off because I can see the stripping? Anyone one else experience this? It’s really bothering me.
Also, I wish the instructions would’ve said to cut below the valance outline a little bit. I feel like the gap between the stripping and the top of the bumper is too much when cutting right in the line. Curing a 1/4 below the outline would’ve been perfect.
