Starter "Plug"?
opc11
I just replaced my starter's contacts/plunger. In the process of handling it, I broke one of the plastic/rubber drain plugs. It's about an inch long, perhaps a 1/4 in. cylinder shaped rubber plug w plastic teeth to hold it in the starter. It's on the outside of the starter.
Does anyone know where I can get a replacement other than a dealer?
Thanks in advance.
Thanks in advance.
Go here to find part nuimber:WAIglobal - Worldwide Source
Then buy here:Nation Starter & Alternator,Tractor Auto,Marine,Truck,Small Engine
But if that's all you need, shipping may make dealer cheaper.
Or you maybe can find a local starter/alternator repair shop. I have a good one near me in NJ.
Thanks!
I found something similar to what I was describing but it's not the same. I'm going to do a bit more searching and see what I come up with. Thanks again.
premiumusedautoparts
