152 Sumo
Everyone knows the grinding sound that the starter makes if you accidentally turn the ignition while the engine is already running. Every once in a while, usually in the morning, my starter makes that noise when I first try to start it. I then have to stop for a couple seconds and try again with a normal start on the second try.
Here's my question: Does this mean the starter is starting to go bad, or is this something that replacing the contacts would fix?
I did some searches on it, and obviously it is easier, and probably cheaper, to replace the contacts. I am hoping to do some preventive maintenance and have it fixed soon so I don't get stranded in some random spot. Especially since my wife's family from Japan will be visiting next month and I will be carrying everyone around in the 4RNR.
