Stock ride height difference
spoonmectr
So I saw some stuff posted on older 4Runners but I havent seen anything on 5th gens. My factory front ride height is 3/4” lower on the left. I installed the TRD Pro suspension today hoping it would correct that but it didnt. 1” higher but still lower on the left by about 3/4”. Surely im not the only one??
It's not just you. A Google search of "5th Gen Lean" turns up the following:
Thank you!
Im not sure why Google didnt find anything relevant...
You'll probably have better luck if you use the forum search, advanced, then select the 5th-gen area before putting in your search terms.
Oh, and ignore the lean. You've got an awesome SUV.
So I saw some stuff posted on older 4Runners but I haven't seen anything on 5th gens. My factory front ride height is 3/4” lower on the left. I installed the TRD Pro suspension today hoping it would correct that but it didnt. 1” higher but still lower on the left by about 3/4”. Surely im not the only one??
The lean you are noticing isn't going to hurt your truck and isn't abnormal.
Adjustable coil overs or OME trim pack spacers can fix it somewhat.
Grab some beer and a chew and starting searching this forum. You should be done right around Christmas time.
Jhunt
