Subieled led fog lights
saskrunnerpro
I’m thinking about purchasing these subie led x3 bulbs for my fogs. Was wanting to go with the 3000k yellow paired with the yellow Laminx . I tried searching in the forum with no results . Does anyone have any experience with this company or products ? Any input is greatly appreciated!
Here is the link
Home
If you want to use yellow film, go with normal 4 to 5k LED light bulbs.
If you don't want to use yellow film but want a yellow light, then 3000k bulbs will work.
I wouldn't combine the two, due to loss of lighting.
Not sure about the brand you want to buy. I would stick to reputable brands or vendors. I've bought no name LED bulbs in the past. Some have worked flawlessly, others have had flickering problems or self destructed inside my housing.
Ok thanks for the info , i was also thinking about getting xenon depot leds for the fogs, just not sure what it would look like with 5500k and the yellow laminx
xenon depot is legit. 5500k with or without laminx will be bright as heck due to the light dispersion but you should be happy with them.
I had that setup for a while as do many others before going to a plug and play LED fog light w/ led housing (baja/rigid/morimoto/etc).
Thanks appreciate the input , will go with the xenon depot leds and laminx .
I can second this. I am pretty happy with xenon depot led fog lights.
Jhunt
