SUPER BRIGHT!!! CANBUS LED Backup Lights Perfectly fit for Toyota 4Runner 2000~2021
lasfit
official vendor
attachment.php
Have you accidentally hit the car parked behind you when you back up, even with the reverse camera? Most halogen bulbs used in reverse light are low-wattage bulbs, which don't illuminate well at night. Having clear visibility behind you is extremely important in keeping you and your family safe and allowing other drivers to see you better. Upgrading the stock reverse light to LED becomes one of the must upgrade for 4Runner owners. Replacing the stock halogen reverse light with LED is very simple. You reach the reverse light, turn to release, pull out the halogen bulbs from the power plug socket, and plug in the LED bulbs. And you're done! Please refer to the installation video guide and skip to 11:30
The reverse bulb size for the 2000-2021 Toyota 4Runner is 921, the 2022 model has factory LED reverse light. Lasfit T series T15 LED bulbs are specially developed to replace the 921 halogen backup lights. You guys can learn more details from the link of T series T15 LED bulbs: 921 912 White LED Bulbs CANBUS Error Free For Reverse Back Up Light
● High Intensity.
Truly 1500LM, 13W per bulb, 6000K cool white. These LED bulbs use less energy and are more efficient than halogen ones. The T15 LED bulb is a tremendous improvement over the halogen bulbs. They are incredibly bright and make seeing at night so much easier!
attachment.php
● Plug and Play. Canbus Ready.
These T-T15 LED bulbs have built-in CANbus system and require no extra wiring harness or resistor. They directly replace the stock halogen bulbs, super easy installation.
attachment.php
● Reliable quality keeps your safety
Lasfit T-T15 LED bulbs are made with aviation-grade aluminum for efficient heat conduction and heat dissipation, ensuring a longer lifespan. Canbus ready, error-free. High-quality LED chips, high-efficiency output lighting, 1500LM/bulb. One of our customers said, "I installed the LED reverse lights, and they make all the difference in the world! These things are ridiculous, and they are super bright. I'd recommend these things to anyone. Definitely worth it."
attachment.php
If you're still keeping your stock halogen backup lights, would you like to try Lasfit T-T15 LED bulbs? It will be a simple upgrade but will make a huge difference!
attachment.php
attachment.php
attachment.php
I'll have to give these a try. I got some good LED's off Amazon but i want more!
I do have roof mounted pod lights but they are way too offensive for street.
lindwlson982
