Taco manual hub swap, yea or nay?
octanejunkie
Elite Member
I've seen Tim's video and I like the idea of not constantly turning CV joints so I'm interested in this mod when I convert to 4WD.
Anyone here who's done it and lives with it care to share how much they love it or was it more trouble than it was worth?
Sent from my Pixel XL using Tapatalk
It was more trouble than it was worth but I love it a ton anyway. Does that help? :bounce:
I can actually feel the decrease in drag when hubs are unlocked. It's not a lot but noticeable.
I did the warn manual hub conversion on my 2nd gen 4runner. I actually gained gas mileage and felt good about not being disabled by a broken CV scenario. what's the timeline on your swap?
it does make maintenance on the front end a little more involved but not hard. since you have to get them dam cone washers off. brass bar/drift is now in your toolbox and you will learn how to get them off pretty quickly.
other than that I love it, would never go back to ADD style hubs for a off-road focused truck. if your not lifted or never go off-road it's totally not worth it.
My thought was to coordinate this mod along with the 4WD swapgrade, so it all happens at once vs. a special project. This way, I only need to do UBJs once and then install my SPD UCAs
Did you do a write up of the Warn swap? What as the all in cost? Inquiring minds want to know :twitch:
Timeline on the swap is pretty much whenever I get all the parts and the time, so between this month and 5 years lol
This truck is my DD and offroad/overland rig, lifted 3+ inches. I like the idea of keeping wear on the CV joints to a minimum and I don't mind getting out to lock the hubs
Wouldn't put 600$ into the hubs alone, but for a couple hundred bucks in junkyard parts it's worth it. You'll never lose a CV boot again driving down the road.
A 4x4 swap is where they really shine though. Since you're already replacing a ton of stuff anyways if you can get your hands on a manual hub setup it'll make the swap easier. No plumbing or wiring, just drop it all in.
Sent from my Z981 using Tapatalk
It's kind of a pain because you'll need to get the knuckle assemblies off a truck that had manual hubs. You'll then need to press the manual hubs out of those knuckles and have them pressed into your knuckles along with the necessary tone rings and locking collars. This is the only way to get manual hubs and keep your ABS. Probably isn't worth the effort and time finding parts if you already have 4x4, but since you're converting, it's probably worth that little bit of additional effort.
The 2WD front hubs are VERY similar to manual 4WD hubs. I haven't checked if the parts are the same, but the locking collar on the wheel bearings looks the same, and there is a giant hole through the center of it all... The hub just isn't machined for a drive plate. That should mean it is possible to keep ABS with manual hubs.
-Charlie
I'm glad this came up. My brother has a 95 tacoma 4x4 that he's using to swap its 3rz into his 85 4runner. He said I could have the hubs and anything off it if I wanted, but I read its kind of a pain if I wanted to keep my abs which I do since the truck it would come from was non abs.
Anyone that can chime in that has converted non abs manual hubs to abs manual hubs? How bad was it and was it worth it? I really would like to minimize cv boot wear but I don't wanna loose my abs either
Level of "trouble" depends on tools, skill, space, experience, etc. 100% worth it to me.
I got all my parts for $300- with OEM axles.
Had new bearings pressed in, new backing plates, knuckle gussets while I was in there, and good to go for another 150-200k miles.
I didn't want my axles always spinning, and like doing cool OEM swaps. I don't think it's worth it if you're doing it for MPG savings, and it's a hassle to have to get out and lock the hubs if/when you want 4WD on the fly.
That said, leave them locked, and it's back to being like regular old auto hubs [emoji12]
Manual hub poser pic.
It's not a matter of being "bad" or "not bad", it's all about what you want, and your abilities.
It's a super easy swap, and no different than having new wheel bearings pressed on. The only difference is you have to pull off two per side, and press the manual wheel hubs(with ABS tone ring replacing the spacer!) onto the ABS knuckles. Easy peasy.
Talk to me
http://www.toyota-4runner.org/3rd-gen-t4rs/218742-mile-marker-95-29918-manual-hub-conversion.html
Mile Marker 490 Premium Manual Locking Hub Set
by Mile Marker
https://www.amazon.com/Mile-Marker-95-29918-Conversion-Automatic/dp/B000FQ7WI2
Talk to me
Stay away from all that.
Just be patient till you find a Tacoma you can use the OEM Aisin locking hubs and OEM axles from.
You can buy the manual wheel hubs new, and just have them pressed onto your ABS knuckles- if you are keeping ABS. They aren't cheap, and you'd still need the locking hubs and axles. That said, you can go aftermarket on the axles if you're into that, and then you would only have to find the locking hubs. Easy to find, and much cheaper to ship vs having to shop axles and the whole knuckle/wheel hub assembly.
[MENTION=95183]octanejunkie[/MENTION]
Have you thought if you're going to try to swap in the whole ADD system as well? One benefit of going manual hubs is that you could also use a non-ADD diff tube. Then you have no vacuum or electronics (except at the transfer case I guess). You lock the hubs, pull the shifter and off you go.
Yup, that is the basic plan if I go with manual hubs, it simplifies things
They're also cool for easy 2LO [emoji12]
I actually just used it the other day. Pretty nice.
Gotta lock the center diff if you have one though, otherwise you ain't movin!
AndiGarage
